Just Sold
- May 18, 2010
- 3
Hi,
Hoping that you restoration guys can help me.
I have a 1972 14' Starcraft Falcon that I purchased recently. We had it out for its first voyage yesterday in NH and it performed well but.......
So here is the problem .... some of the rivets and a couple of seams are leaking. I had done a water in the hull test at home with only 2 small leaks. All the flexing on the water just showed me where the real problems are. None are major and only a couple dripped to the ground when I re-tested with water in the hull upon returning home.
So without removing the floors what will work best to seal these leaks until I can remove the floors this winter and work on it in more detail?
I will install a bilge pump but that is ok to a point and does not address the problems.
