Alpha One
leerocks
Doe anyone know how to tell what generation my alpha one outdrive is? My trim limit is out of adjustment and was wondering if the generation dictates what measurement to set the trim limit. I may have used the wrong measurements if there is a difference.
Thanks,
Jeremie
leerocks
Re: Alpha One
Thank you. The measurement I am using is the 20.75 inches for the trim limit but does not seem to be enough.
Bt Doctur
Re: Alpha One
Using the trim up button ,the drive should stop it`s travel when that measurement is reached measuring from shaft to shaft
