Hi, I have a -89 Mercruiser 3.0 with alpha one. I am going to change the outdrive. The currently drive upper gears are: U-joint shaft 17, vertical 19. The new drive has: U-joint shaft 20, vertical 24. So i counted the upper gear ratios: 1,11765 and 1,2.
I am thinking, that this 1.11765 isn't the original gear ratio for this engine, maybe someone has changed the upper unit before(from V6 maybe?) but the 1,2 would be the correct gear ratio for this engine? Am I right?
