1992 Mercruiser 5.7L Alpha One Gen II, Just replaced the gimble and all went well. Having alignment issues. I have the tool and checked it to be sure it would fit before I installed the new bearing. Front end of tool went all the way into the splines on the engine side and the bearing fit correctly on the thick side of the tool. When I insert the tool through the bearing it makes contact with engine splines but only goes about 1/2 inch (or so as evidenced by grease marks on end of tool). I've tried tilting the bearing slightly up/down and sideways but no help. This is a first for me so I'm not sure how much I should do that before I start moving the engine mounts. Please advise. If its time to start adjusting the engine mounts where should I begin? Front or rear and should I go up or down first? How many turns of the bolts should I do at a time (unfrotunatly I will be doing this without a helper). FYI - When I removed the outdrive it was a real bugger. I had to shimmy and pry it 1/4 inch at a time for about 2 inches till it came off. The spline had dry black crap on it(just like Don S suggested in a prior post) so clearly it had not been removed in a while. The teeth look good so I'm not concerned about them. As always, THANKS FOR VALUABLE advice.
