I have a 1989 Evinrude 70 with VRO, on a Bass Tracker Pro 17. I took it out this past weekend for the first time since October. Went out, fished a while, started back to the ramp, just idling along slowly and the alarm horn in the remote control box went off with a steady/constant loud sound. I immediately looked back at the motor to see that the pee fitting was shooting a normal straight stream of water and my water pressure gauge on the dash was working just fine, so I shut her down anyway. I waited a couple mins, then turned on the ignition, not starting the engine, and the horn still went off steady and loud sound, even without starting the engine. It did this several times, so I turned it off, dropped the trolling motor and continued on my way for about 15 mins. Then I went back looked at the VRO tank, oil level was fine (almost 3/4 full), but I pumped the primer a couple times (it was very hard to pump) and turned on the ignition again and the horn did not sound this time, so I started the engine. No horn sound, water pressure great, and smoke from the engine as normal, indicating to me I was getting oil through the VRO system. I went ahead and ran the boat all the way to the ramp using the engine, which took about 10 mins....I ran it back and forth a few times at full throttle to idle and the horn never went off again. I trailered the boat and came home puzzled. So, is my VRO system ok, my water pump ok or what? Does anyone know?
