I see both you and GM280 misinterpreted my logic. Using one of the switches on your new panel would merely supply or cut power to the rest of the switches on that panel. It is not intended to power every device directly. In fact that scheme is very much like your house wiring in that the MASTER is the MAIN breaker in your breaker panel. It powers the other breakers which in turn powers each circuit. My contention is also that why switch a device that already has a power switch. You now have to hit two switches to turn on any switched device. With a MASTER switch the panel is now powered. Turn on any device at the device rather than having to hit a separate panel switch first. Devices like bilge pumps, lights, etc need a separate switch. Radios, locators, GPS units do not. But -- it's your boat, do whatever lights your fire. There is nothing unsafe about using a MASTER switch.
