Texasmark
- Dec 20, 2005
- 14,562
Re: Add-On Outboard Motor Overheating Alarm?
What about your exhaust water jacket cover on the left side. Nice flat surface. Don't remember if you had a stat or not. The exhaust is a separate circuit from the block, but will tell you if the water pump is pumping. If no stat, then you should be good to go.
Course, with a couple of tubes of JB you could paste it right above and slightly to the right where you have it in the picture. Then it would monitor block temperature. On your comment about removal and all that, you are being picky again. If you want it off later chisel it off. But what difference does it make if it's on or off. Some people are just too picky to please. They want help but have all these strings attached with impossible amenities. I'm through with this thread.
Mark
Mark
