I have a 15' vee hulled runabout, a 1969 Glasspar with a constant vee (don't know the deadrise angle exactly) and I am running a Honda 45 on it.
The engine has the standard equipment 11 //4 X 13" pitch three blade aluminum wheel on it. The cav plate is even with the bottom of the hull, there is no spray.
With two passengers or for that matter four, the thing turns 57-5800 RPM wot, speed is 29-30 mph depending on wind etc.
Honda specs 5000-6000 Rpm wot for this engine.
Should I:
1. Buy a 14' pitch three blade aluminum?
2. Have cup added to my current prop?
3. Buy a stainless prop of the same pitch as I have now?
I would like to get the RPM closer to 5500 and pick up a little bit of speed, I realize 1mph may be all I get.
Should I:
