GSX455
- Aug 21, 2016
- 157
I had to remove the motor and raise it up to install a new steering cable. When I raised the motor, the tilt was higher than normal. I started to leak hydraulic fluid from the bottom, on a Johnson 90 HP motor, how do I add any hydraulic fluid? it stopped leaking once I lowered the motor.
Thank you
Thank you
