ok ,fixing this thing fo a neighbor ..<br />so far , replace the trim relay/sender box ..($185 ) wow ..but that fixed it ..( two relay's ,and a sender in a epox box ) <br />cut open the trim motor ..cleaned water.corrosion out ,and it now runs ..( welded /silicone back together ( new one $175.00)<br />oil pump drive shaft twisted in two ..ordered one , and it is a "new "improved deal .."<br />requires pulling the engine to get the flywheel cover off to install..<br />hmm made a new one on the lathe/mill ..that looks like the old one ..simple install..<br /><br />man these parts are expensive .<br /><br />now the question !!!<br />dealer say .only Barbardier synthetic .oil <br />bought one gallon .$39.60 ..<br />what else can we run in this 10 year old two-stroke????
