I never would have guessed that is what it did, the PO knew nothing about the boat or trailer. Also didn't realize how far up the motor tilted. Thank you
Now that I understand this. Should I be using a transom saver in addition to locking the motor in this position?
http://www.iboats.com/Springfield-A...79117430--**********.938570799--view_id.20695
It's a trail lock. You push it down to support the motor when trailering, etc. so you don't lock up your PT&T.
If the boat is on the water and you want to leave the motor tilted up, you should use the trail locks and withdraw the trim rams.
It's good practice to fully withdraw the trim rams when the motor is not in use, so they don't corrode.
heres a bigger pic
look hydraulic to me....
it may be electrical motor driven...but that just runs the motor that drives the hydraulic system...
bob
How does the 88SPL Run ? I hear these things are nearly bullet proof...
it is electric. the trim/tilt works with the motor off.
i had a "sneezing" issue that ended up being worse than a backfire. my motor was firing 2 clyinders at once. basically as one piston is going up the motor was trying to fire it. not so good. it would have a violent stall. well i fixed it and it runs tits now. im sure if this motor wasnt so bulletproof i would have a much more expensive mechanic bill.
the SPL was supposed to be evinrude's way of keeping cost down. so its basically the exact same motor as the 88 but without electic tilt/trim. mine has this but apparently it was added on after the fact.
also, its the same bottom end as a 115. change the intake/exhaust manifolds and the carbs and you should have yourself an extra 25hp. but i like the reliability of not messing with anything.
