michaelj1978
- Jul 8, 2004
- 50
I'm currently running a 96 Evinrude 50hp on my 18 foot aluminum jon boat (don't know the weight, but it has full interior). <br /><br />A problem that I'm having is I'm running a 15pitch prop and the rpm's at WOT are going above 7,000. Of course I don't keep them there, I try to run it at about 5,900rpm's for top speed. <br /><br />The highest prop pitch I can get for the specific motor is 19. What are the likely effects of going from a 15 to 19 pitch. Run smoother? Faster? Less RPM's?<br /><br />Also...The motor has tilt/trim buttons on the motor itself as well as the throttle/control box. The buttons on the motor work fine, but the ones on the control box are no longer working? Could that possibly just be a fuse or a larger problem.<br /><br />Thanks!
