This motor has a clicking noise that seems to occur about once per rev that is noticable at idle. Sounds like valve clatter. Any ideas? Is is normal or a problem? <br /><br />Also, the boat tops out at near 6000 rpm, 35 mph or so with a 21 pitch prop. My glastron gets much more speed per rpm. Does this sound normal? can you have a spun hub that will perform this well?<br /><br />Thanks
