I have a 94 evinrude 115, e115tlerc. it pops at idle and sometimes will not idle at all, runs fine or better anyways above idle. compression on all 4 cylinders was between 115 and 120. ordred carb rebuild kits, installed and same symptoms. while running with muffs on i used a temp gun and the lower port cylinder was about 10 degress warmer than the rest.(lean condition) i sprayed carb and choke clean around lower head area and idle changed, smoothed out. i pulled head and what i believe is called the bypass cover. gaskets looked fine. is there anything that is common or that i might be missing. also when i pulled the plugs before i did anything i pulled the plugs and they were all nice and brown no indication of lean. and previouse owner had dissabled oil injection and had been premixing gas.
Thanks in advance
Jeff
Thanks in advance
Jeff
