This boat is still bogging down and shutting off at WOT. Its a bear to start and idles like crap, here is what I have done. Checked compression on cylinders 105,106,107,114. Check spark on all cylinders great spark. Rebuilt the fuel pump a couple months ago, just cleaned and rebuilt carbs, looked at reed valves, no cracks or bends at all when I pulled the carbs. New primer bulb, new fuel lines. Rectifier recently went out replaced rectifier, tach went out at the same time, even with new rectifier tach still not working. New plugs champion JC4 plugs gapped to .40.....When I first put her in the water after rebuilding the carbs she ran like new for about 5 minutes and then shut down. I did pump the carbs full of fuel after the rebuild and there were no leaks in the carbs or any of the lines. After she went down hill she stayed there, limped back to the ramp and here I am back at square 1, this almost has to be electrical right? Please any help is much appreciated. Also performed link and sync to manual specs.
