I have been getting all sorts of different answers to this. Can someone give me the real deal. I have a 94' Mercury XRi Black Max 175 HP. Serial number is 0G000940. At idle, I get nothing on charging, hit the trim at idle and volts go down in the 11 volt range. At high rpm, this thing will charge at over 16 volts. I have just replaced battery with a good serviceable battery. Should I be getting some charge at idle or does this older system need to be cruising to get a charge. Also I understand I have 2 regulators. Could only one be bad. I understand that because a can get some charge, the stator should be ok. Thank you guys so much for the help. About to head to the marsh and I don't want any problems out there if you know what I mean.
