Ok, Hi all. I have a 93 4.3 with an Alpha I that I bought last fall. The drive serial # is OD889087.This boat was an Indiana DNR boat and has 2200 hrs on it, and it spent summers docked in fresh water. I have a few problems so I will start with outdrive questions.
I have Chocolate colored drive oil when I drained it, found fishing line on prop shaft. I feel I need to replace the Prop shaft seal, however the inside of the housing where the large nut is has a fair amount of corosion. Can the seal be replaced without pulling this assembly out?
Pulled the drive off and gimbal bearing is trashed. I also found small amount of water in bellows, however u-joints and drive shaft show no signs of rust and look/feel good. Can I get the gimbal bearing out without buying Merc's special puller?
Figured I would replace all the bellows and such while I'm into the drive. I have a Seloc manual, but would like a link to the Merc manual...
I'm also having power steering and shifting problems but I will start other treads for those questions...
