Hi all
My motor will not idle down low and can be a pain to start unless i crack the throttle blade by putting a stick between the roller and the cam plate. I am well versed with the 9.9/15s with the throttle blade opening a touch when it hits a mark.
With this motor at 0 throttle i don't get to the marks and the throttle is shut. At fast idle it is not open at all either. There is not much movement either of the armiture between the two. Does anyone know what the marks mean and what i should be lining up to get it to start well and idle low.
I am going to go pull the carb and clean it up, would love to know how to set up the throttle.
No matter what i do with the throttle it never gets the roller to the marks on the armiture.
