Went to start it up after sitting for the winter and it started right up. But the oil reservoir on the engine leaked out of thru the top cap that includes the low oil sensor. I took the cap off and retightened it, but it still leaked when the engine was running. Both oil reservoirs are filled with oil and the top is on tight on the remote oil reservoir too. The oil that leaks comes out of the small engine tank reservoir at a steady rate. I thought the low oil sensor in the cap might be stuck at the open position and that the oil pump doesn't know that the resevoir is already filled. Any thoughts would be helpful and apprecaited. Thanks, Joe.
