Riverrat8428
- Feb 4, 2008
- 37
Starts great takes off and in about 3-5 minutes drops one cylinder than drops another when I try to determine which cylinders it appears that the two top cylinders drop out and run on the two bottom. We changed out the power pack (used) same problem changed out the stator and trigger same problem also (used),, Definatley seems like ignition and not fuel.. Just wondering if anyone has had this expeirence.... Ingnition parts are expensive trying to be smart about which parts to buy... All connectors have been checked and cleaned.... Any Help is welcomed......thanks b
