Re: 91 150 evinrude compression
okstatefan, it really doesn't matter what the compression is at this point....everything has to be seated properly to "seal", so until the engine is broke in, it is of no value at this point.<br />JB's answer is not incorrect, as they should, technically, be within a few pounds anyway but compression readings will mean more at 20-25hrs.<br />Another fact I've been made aware of is the "Idle break-in" procedure....let the engine Idle for 3-4hrs to allow cylinders to warm to temp, T-stats open and cool back down and the cycle continues and is considered the "Best" way to properly break in an O/H as the temp goes up and down without creating over-temp or super high combustion temps.<br />Engine would need to be in a tank or boat on the water tied to dock for proper back pressure for this.
