jmoorepghpa
- Apr 17, 2006
- 114
I have a 2001 Evinrude 9.9 I want to install as a kicker on the boat in the picture. We are on the river here so I defanantly wand the kicker as a back up motor and serveral of the lakes around are hp limited. I'm liking the spring loaded motor mounts they make that allow you to raise and lower the kicker. My questions are these--
1. should the kicker be on the side opposite the helm to balance the weight of the driver--- I have always had them mounted on the port side.
The 9.9 is electric start and has control cables not a tiller--
- should I install the throttle controls up to the helm, lock the 9.9 in the forward position and use the lower unit as a rudder, try some kind of steering-link-bar set up or just get some sort of tiller extension device.
3. If I run control cables I'm wondering about where to come throught the hull and if I really want to do that.
