I have a 2000 rope start, tiller handle model e10r4sse it did not come with electric start. I have measured voltage from a plug that comes out from under flywheel and I get 70v ac at idle and increases when revs up.there yellow wires and from 1 wire to ground its around 30 v and other is 28v and thats on the ac scale of my volt meter.no readings when on a dc scale. I bought the correct regulator that comes on the electric start model. when I installed regulator and connect it puts out 24 volts dc on red lead 0 -4 volts on purple lead and 0-4 volts on grey lead. All these readings are without a battery hooked up. Will i be able to connect to a battery and charge it? the red lead is for battery and grey is for tach and purple is for ignition those i do not need. Just looking to charge battery as I troll. How do I post pics?
