89 force
osceola
I have 89 Force 125 on A 89 Bayliner Trophy the problem im having is this. When i start the engine and put in forward just above idle, the engine will rattle or shake. But once you open it up it runs great. Wide open it runs about 5200 RPM and around 30 MPH. It idles good. Just when you raise the RPM up a little it will shake or rattle.
Thanks Osceola:D
foodfisher
Re: 89 force
Don't know how to guide you to previous posts, but they all say "the nature of the beast".
jerryjerry05
Re: 89 force
Re set the carbs.Check the reeds.Check compression/spark.Replace the fuel pump diaphragm.Top of the Force section is a thread for a linc and sinc from Frank A. Do the linc and sinc.
I've heard that some oputboards just won't accelerate good.Of it's set up right you shouldn't have a problem.Do these things and post the results.
My twin 88/85s idle and accellerate great.Jerry
osceola
Re: 89 force
TO Justinde This is a help section for people trying to get a little help with thier boat or engine and not break the bank. We don't need smart *** people here. So grow up and act like an adult.
Osceola
osceola
Re: 89 force
Thanks jerryjerry05 The spark is good. Compression is 132 ea cylinder cold.Will check the rest and get back with you.
jerryjerry05
Re: 89 force
Fill out the profile you might be close to someone who can help.Jerry
RRitt
Re: 89 force
my guess is that jerry is spot on with the carb synch. suggestion. It could also be one carb has more winter gas residue than the other.
osceola
Re: 89 force
Today i decarbed the cylinders, rechecked timing, reset lingage and adjusted carbs. Its suppose to rain the next few days so i won,t be able to put it in the lake. When i do i'll let you know how it runs.
Osceola
osceola
Re: 89 force
Today i had the boat on the lake and it ran good. I had a mechanic to check it out he said the compression was 145,145,152 and 90. Cleaned carbs and said needle jet had a slight ridge but was ok. The motor ran great. Thank to all of you for your help.
Osceola
jerryjerry05
Re: 89 force
That 90# on the bottom is gonna be a BIG problem.Try a decarb.Possibly remove the head and check for damage.It's only 30$ or so for the gasket.
Waiting too long can possibly cost a BUNCH.Too long and the cylinder and pistons can be shot.Jerry
osceola
Re: 89 force
sorry im late getting back. Took the head off and looked at the bottom cyclinder. It had a couple of bad scratch marks in it. The cyclinder is going to have to be hone and oversize rings put in.
