888 to 140 housing swap
Odiesoxx
Couldn't fin an old thread on this, so here goes.
Just bought a 74 bonanza 18 foot with the 188 up mercruiser 888 drive. The upper housing is broken where the tilt/trim cyl attaches. I was given a second boat with a mercruiser 120/140 with a bad engine. I know the ratios are different, so can't just swap,the outdrive, but can I swap the upper housing? Are they the same? How tough is it to swap the gears out? I am mechanically adept, as a 25 year auto/aircraft mechanic, but haven't ever dug into an outdrive before. Any help is appreciated!
Darin
Bt Doctur
remove the drive, remove the engine , swap inner and outer housings.
If you can do a rear end, you can change the gears
achris
More fish than mountain goat
Swapping internals means running through the shimming procedure. The tools to do that alone will cost more than a new upper complete.
Odiesoxx
Along these same lines, I have looked for a printable service manual link for this setup (188hp 888 drive), but the links I have found are dead or corrupt. Can anyone point me to a good link?
Odiesoxx
okay, I found a link for a manual that works, but now I have another question: where is the gear reduction in the drive? Top ring and pinion, or bottom ring and pinon. if it is at the bottom, can't I just swap the complete upper half with gears and shafts installed?
Ayuh,.... Welcome Aboard,.... Gear ratio is determined in the upper unit,....
The lowers are all 1.65:1,....
achris
Welcome to "BOAT"ing.... Break Out Another Thousand.....
Odiesoxx
Not new to this game, had an 85 30 ft party barge and an 84 50 ft Myacht on Powell. What is new to me is sterndrive. Always had outboards before.
