holorinhal
- May 26, 2009
- 119
I have a 1988 oil injected 100 hp merc. It had been sitting for about 15-18 years, since my dad took the motor off the boat, because he thought it had a oil problem, due to a constant beeping oiling alarm.
I have since figured out that it was a problem in the oil tank, with the float.
I have got the motor to fire up and run, however, it will run rough and wont run for long, on its own or sit and idle on its own, with out aplying throtle.
While running and applying throtle, i noticed that fuel sprays into the carbs, only on the midle two carbs( #2 & #3).
I have a new pump bulb and fuel suply line, however, I am drawing fuel from a regular gas can. Is this ok, or are the outboard fuel tanks preasureized?
I have checked the compresion and all cylinders read 120 psi, except #3 which reads 115psi.
Are all four carbs supose to spray fuel on acceleration. Is it possible that #1 and #4 are cloged?
