I have a 1996 88 spl (flatback) that I am hopefully going to rebuild for various reasons. One issue I have is not being able to pinpoint the source of water found in the port side cylinders. Cylinder head & head seem flat with in .004" spec. Inner exhaust cover shows over .004" around the center-line water channel but I can't find a serviceability check for flatness on this component. Does anyone have experience with water leaking into exhaust chamber / cylinders due to flatness issues with this component? I replaced both cover gaskets back in the summer but it did not correct the problem. FYI...heads look steamed cleaned, piston domes do not.
