hankll
- Sep 10, 2006
- 224
Really need some opinions of what best do to do. Rodbolt speak up.
History: Had 87 DT150 SS, Burned piston, broke rod on #1 cyl
Bought 88 DT150, bad lower unit.
Switched lower units, switched motors
87 had oil injection, 88 had oil injection removed
Premixed gas in on board gas tank
(now realize) forgot to clear pick up tube and gas line leading
to splash well/primer bulb hose
Started 88 on (now realize) raw gas
Motor seized after about 5 min., (realized had a problem)
Sprayed penetrating oil in each cyl, spark plugs oily, no trash
spun over engine without spark plugs
Re installed spark plugs (stupidly) restarted motor
Heard noises, shut down, checked spark plugs
Had trash around cone of #6 spark plug.
Did a compression check with finger over Spark holes
Had no compression on #6, all others, O.K.
Pulled head - found this - and More
What can a shade tree mechanic with a little experience working on motors do with this. I checked bores, thinking to change jugs and pistons from 87 but 87 has been bored .015 over. Found the hole in intake side of crankcase on the 88 but have 87 crankcase that appears to be good. I could just buy a new piston/ring set for that cyl in the original size, or change the whole jug with pistons from the 87. Rod appears to be good, don't know condition of crank journals. All cylinders appear to be in o.k. shape, no scoring. Whatcha think?
