Help! Ran great last year, This year as soon as you give it throttle it kills unless you choke it and get it past low/mid range then runs great at fast speed and choke pushed back in. It will idle great after warm and trolls all day. I heard that piece of gasket material will often plug up jet. Also the Carb is leaking slightly, so looks like I have to pull off the rope starter to get off the carb then new gaskets and clean out jets. Should I buy OEM gaskets from dealer or Sierra from elsewhere? Too hard to get carb off to make a mistake on gaskets. Will jets come out with good screwdriver? Never done this type of carb before.
As always, I appreciate you guys that take the time to answer.
thecruiseguy@comcast.net
