Hey guys. I just bought a fixer upper with a 115 Mariner on it...with a bad lower unit. Well before putting down the cash for a used lower unit, I decided it would be prudent to check compression and it all looked pretty good until #6. 1-4 all ~120 and #5 was 115. But #6 was only around 30.
I poured some oil in and retested and it jumped up to 80, so it's looking like stuck rings...or a melted ring/piston mess.
I bought it with the lower unit removed, so obviously these test are with the motor stone cold. So should I try to get some water to it, warm it up and Seafoam it before losing all hope...or is #6 most likely toast?
Thanks for any feedback... I know the answer is probably, "don't know...all you can do is try", but I thought I'd ask for opinions anyway. If nothing else, this let's me share my disappointment with a group of like-minded folks.
Thanks,
Tim
Thanks,
Tim
