Re: '87 DT 150 SS burned piston
Hey thanks for the replies.... I've yet to get a chance to get started on this situation. I talked with my local mechanic (the one that has done any of the work I couldn't) He says to take off the power head and it'll save me money on the labor. And he'll take a look at the damage. He indicated (if no major damage) I'd be able to keep repairs to less than $1000, even possibly as low as $600, which was re-ring all 6 cyl while honing the good cyl's, and look at the #1 cyl condition and determine whether to re-sleeve, or bore over size. I think he mention that a Suzuki could over size as much as .0060 and I though that was a bit much. WITH ALL THAT SAID.........
I've located an '88 DT 150 that lost the prop and prop shaft while motoring on the Tombigbee waterway (He thinks the bearing seized) So for the money, $500, possibly less, I thought to just replace my lower unit and swap motors...
I believe they are compatible with each other. The only loss I'd have, is his motor isn't a SS, but he said it ran good. I'm trying to do this myself. Any advice about changing out lower unit, would be appreciated. Gaskets, impellar, and any other items I need to think of. Been studying the manual in prep for when I go get it, to be prepared. Need a motor lift(rental), but think this is the way to go....whatchya'll think?
