canoemang
- Apr 9, 2011
- 350
Yesterday i noticed my system wasnt charging but my tach was working. I got home and tested the rectifier and it was bad, swapped it out with a new one. At WOT it charges at 16.5 Volts and the tach works fine.. at idle the tach gets erratic and it sits at 700 which is where i have it set to idle then crawls up to 1500 rpms then drops back to 700, during this the throttle is at idle and the motor doest rev.. just tach climbing..
It didnt do this with the bad rectifier.. New one also tested good prior to installation.
connections are clean and tight.. any idea?
