Hey all, i have a 1986 johnson 50hp outboard that stalls when trying to take off in gear, runs perfect past half throttle and up. i have checked compression 135 on both cylinders, spark jumps 7/16 gap, checked fuel pump diaphram and rebuilt carbs. If i catch it just right before it dies i can bump key in real quick and it will pick up and stay running. Also when running on muffs when it tries to die i can squirt premix into bottom carb and keep it running. I have checked the carbs multiple times as it seems the problem is in bottom carb but can't find anything. Any ideas?
