tmaxx26power
- May 17, 2017
- 9
First off Im new to boats so knowledge is very basic. I bought a 84 Bayliner with 85HP Force motor. My first run out on the lake if I let it idle any length of time or went slow speed to load on the trailer the temp alarm would go off. So I took it to the shop and they installed a new water pump kit and thermostat. I haven't taken it out yet but today I put the elephant ears on it, turned on the water and fired it up. Right away I checked if water was coming out the 2 little round ports of the back of the motor and there was nothing. I only let it run maybe 10 seconds at most and shut it off. Should water be coming out those ports right away or does the thermostat have to open first? I touched the head and it was barely warm to the touch. Thank you
