Re: '84 Evinrude 115hp Loss of Power
That engine has two power packs. You said you replaced one-how did you know it was bad? How about the other old pack still on the engine-have you tested it for good spark when warmed up?
The only power pack I am aware of (again, new to the world of outboards and boat electrical) sits on "top" of the engine ago e the plugs on the back side of the engine. This was replaced by the prior owner 08-09 (or 08-10) prior to my purchase in 10-10.
I am assuming that if the engine runs smoothly in idle at all Rams that charge and spark are working fine. Would electrical issues arise under load (ie in gear and moving the boat) that would not be evident in idle?
Also, I am assuming, as far as the engine is concerned, that the battery only provides juice to the starter motor and that once the engine is running the battery has no impact and, in fact, is getting re-charged from the engine. While operating I am assuming the battery is only supplying "juice" to the radio, GPS, lights, bilge pump, etc.
