Riverrat8428
- Feb 4, 2008
- 37
Noticed that the new water pump kit has an O ring that should go some where in the impeller housing either above the impeller b/t the top (housing) and the impeller or beneath the impeller sealing the impeller bottom and the water pump plate? Which is correct? Also I notice that the new impeller has a grove for this O ring. Is there a top and bottom to this new impeller? Please help.
