Solomon Shaffer
- Sep 4, 2009
- 60
My '81 Mercury 50hp with some issues:
It stalls at low RPMS, is very hesitant to accelerate, and doesn't
run above aprox. 2500 RPMS under a load. Sometimes I have to
use starting fluid to get it started from cold...
I've replaced:
-Stator
-Fuel lines
-Sprayed Sea foam in carbs (Note on that: When I set it on a higher idle and sprayed the SF in the bottom carb, the motor sorta coughed & lugged under sightly (as I expected.) When I sprayed it in the top carb, the motor revved up pretty high. That probably means that the top carb is not getting [as much] fuel, correct?)
Previous owner rebuilt carbs in October.
Compression was good according to mechanic at
the Marina where the owner had it serviced.
Click here for video of problem (at idle)
(I do realize that by turning the gas thing that I'm turning, it's probably not advancing the spark...but it behaves this way if I'm up at the controls.)
I've replaced:
-Stator
-Fuel lines
