lbcboating
- Jul 21, 2013
- 36
80hp v4 is only getting about 7mph max on 16ft boat.
At first the motor would only run steady at idle and no more than half throttle. If I gave it more than half throttle it started to choke and die. I later realized the fuel tank was not being vented so I unscrewed the vent bolt and I no longer have that problem. I can give it full throttle without the motor choking or cutting out but the speed doesn't increase. It runs fine. Just far too slow for it's horsepower and weight of the boat.
Compresion = good
Sparks = good
I'm assuming the next step is to check the Carbs? Could this possibly be a dirty fuel filter issue where not enough fuel is getting to the motor? Or something more related to the carbs? Does carb cleaner do well in these situations or should that be avoided with outboards?
Also could it be soiled spark plugs? Or wouldn't I notice more motor sneezing and cutting?
Compresion = good
Sparks = good
