My 8 Hp will only run at idle if the choke rod is pulled out a small amount. The rod is connected to a cylinder(primer?) that has hoses going to the crankcase and the carb--there is no choke butterfly. I cleaned the carb it did help. The engine runs fine at all other throttle positions above idle. Could there be an air leak?<br />Thanks<br />Lakeguy72
