I have a 1979 Johnson 70hp w/ single lever controls I picked up the other day that is having some issues. I went to look at the motor, heard it run ,tested the shifter for proper shifting/movement etc etc, all seemed fine. Motor was mated to a 16 foot K&C Deep V (max rated for 90hp). Had it on the lake today for the first time to test things out. Started engine with no problems and let it warm up (using warmup/start lever on top). After ten minutes of ideling I headed out to open water to see what it could do. Here's the problem, when i give it full throttle it sounds as though it bogs down and only hits about 2000-2500 (rough guess) rpm in gear. However if I put it in neutral and manually move the throttle at the carbs, I get full rpm. Also, the prop spins freely in neutral and you can feel the compression when you spin it in gear. No grinding or any other indication of obvious damage.<br /><br />Any thoughts?<br /><br />One quick related question- is it possible I hooked up the 2 control cables backwards? I don't think it is but I could be wrong!<br /><br />Links to photos of motor and controls for reference<br /><br /> MOTOR <br /><br /> MOTOR 2 <br /><br /> CONTROLS
