reference123
- Jul 18, 2004
- 118
I have a 78 OMC 225 (chevy 305 small block) that came stock with the quadrajet carb. Quadrajet had problems so I replaced it with the Edelbrock 1409 (and the proper square to round bore adapter). Added an inline fuel filter and reran all appropriate lines.<br /><br />Used the original throttle cable and attached it to the Edelbrock throttle by running a bolt through the edelbrock throttle attachment and the hole in the throttle cable connector (required adjusting throttle cable about an inch towards the front of the boat).<br /><br />Made adjustments to idle and screws in drive with earmuffs on and had it sounding really good. Took it out to the lake for the first time and found WOT had dropped from 4300RPM's to 3000RPM's using same prop. <br /><br />What am I doing wrong. It was almost as if the throttle was not opening all the way but in the drive it will rev up to 5000 RPM's (only did this for a half second and backed if off immediately).<br /><br />I would appreciate any ideas of what I should look at as the cause of the problem. Also, is there a way to make sure the choke is open (I dont even mind making it stay open as it is generally only used during hot days to start with). I am not sure that is happening.
