I need a little help.
My dad has a 70 hp Evinrude that is hard to start and when it starts on muffs it idles. When we try it in the water it dies the instant I put it into gear. We had the fuel pump replaced but it didn't help
I replaced all 3 carbs with different carbs from a motor I have that runs fine just to rule out the carbs being the problem. No change. So I am thinking it is a spark issue Can anyone tell me the correct ohms reading for the coils and maybe what the compression should be.
Thanks in advance for any suggestions anyone might have for me.
Another bit of info. It doesn't seem to rev up like it should when using the high speed idle lever on the controller
Rather slow to respond when it is raised And when it is in the lake the lever must be raised to get it to idle at all
