Hello All,
I've got a 78 Johnson 25hp that has kicked my butt. I have replaced the fuel pump, soaked the carb in an ultrasonic bath, rebuilt the carb with a new Sierra kit. I've got plenty of fuel and good blue spark at the plugs. I can get it to run on full choke only. I put a new low speed needle in it but it doesn't seem to matter where I tune the low speed. The carb is CLEAN, so I feel reasonably sure its not a trash or old gas problem. I've replaced the 2 vacuum lines on the block. I have checked the compression and I have better than 130psi on both cylinders. I was going to give up and take it to my boat mechanic but he says he's 3 weeks behind and doesn't have time for something that old. Does anyone here have any wisdom they would like to share?
