Hi Guys,
Haven't run this motor in the water yet but I'm working through getting it ready for our summer down here (Australia)
When I bought this motor the previous owner told me it was running a little warm, I decided to inspect the entire motor and just eliminate any potential issues now, I've replaced the water pump, housing wearable parts, water seals etc.
I'll start of by stating that this motor (135483b) has a Pressure Release valve and Vernatherm, The old Vernatherm was locked all the way open and seized, meaning the valve never opens allowing water flow, The Pressure Relieft valve and vernatherm valve/spring are all in good working order and are not seized.
The owners manual does not specify part number for replacement and the best I can find on is #0384719 which does not specify its temperature, Given this is a serviceable part id like to source one locally so that I do not need to wait close to a month to receive it which is how long ordering from the states takes.
Are they any other compatible part numbers that will work in this instance?
