richardbrown67@yahoo.com
- Oct 31, 2010
- 37
My 1980 J70ELCSA started running at about 30% across the power band today, after running strong all summer. All afternoon today I tried all the regular stuff - disassembled and reassembled fuel pump - no change. Swapped with another fuel pump - no change. Tried different gas tank - no change. Tried different fuel line from gas tank - no change. Checked all fuel lines for leaking, including small lines to carbs - no leaking was evident. Bulb pumped up fine. Fresh gas and oil mix. Strong blue spark on all 3 cyls. 120 lb compression on all 3 cyls. Motor has new timer base, stator, rectifier, power pack, coils, wires, plugs, thermostat, all OE parts. Water pump is strong / telltale has strong stream, motor is not overheating. Carbs have new seats and needle valves, OE. Choke works properly. Throttle box and cables work well. So - what am I overlooking? Thanks in advance... Richard
