6902M Lower Unit Water Line
CScherf
Anyone have some way to KNOW that the water pipe is tucked into the rubber insert when placing the lower unit back on? It seems to be in when I get the gear shaft placed, but maybe comes back out when dropping the lower unit the little bit that it takes to set the shift lever screw. How can I verify the water line is in place? Thank you very much for any tips or tricks!
CScherf
Re: 6902M Lower Unit Water Line
Never-mind. Back and forth with the mid-section. Replacing the shift cradle was simple. The rest is the hard part!
