I got a 1250 SS and I had it running and idling good a week ago and checked all seals for leaks.... but when I shut it off the timing jumped and I had to order a new belt since the old one was toast. I threw the new belt on and am pretty sure I timed it right, my manual says at TDC the solid line on the flywheel should be pointing to the center of the crankshaft and the center of the distributor timing pulley. I did that and it says to line the arrow on the timing pulley to the solid line on the fly wheel, okay did that put the belt on. Now when i spin it the arrow lines up with the solid line and the 3 dot line on the flywheel if i rotate it an inch, so it seems to be timed correctly there.
Now when I fire the engine it will start but when it does it's screaming so i have to kill it immediately. My throttle linkage is right and the carbs are shut fully, I rebuilt the carbs so everything inside of them is okay and the idle screws are only out 1 turn. Im at a loss here.
I also noticed in my manual it appears im missing a pointer that points to the flywheel to tell probably TDC It bolted up near the Throttle stop screw area. Could my belt timing be off slightly causing it to go balls out at idle?
