bassin'frog
- Apr 27, 2011
- 103
Got a lot of help from you folks late July/early August, but to no avail. Here's what I have done:
1. New coils (tested good)
2. New points (clean, gapped to 0.20)
3. New condensers
4. New plug wires
5. New plugs (gapped to 0.30, good, crisp, strong blue spark with spark tester)
6. Compression - Upper 65psi, Lower 110psi (I know, shouldn't be that much difference)
7. New impeller
8. Fuel pump rebuild (pump had a lot of crap in it, after rebuild I got a lot of fuel spitting through it)
9. New fuel lines
10. Lync/sync'd
11. Rebuilt carb
Tried starting it a few days ago in a barrel and couldn't even get a 'pop'. It's like it wasn't getting any spark. Switched plug wires around but still no 'pop'. Double-checked spark, and yep, got plenty of spark. Pulled plugs, but they were what I consider fairly dry, not much if any, fuel/oil mix on 'em. Sprayed some fuel in the cylinders, but it still wouldn't 'pop' at all. Fuel primer bulb remained hard. Thought maybe carb wasn't getting fuel. Pulled carb and it had plenty of fuel in it; but while I was trying to start it, it appeared to me the carb wasn?t sucking fuel. Float is mounted properly. Once again cleaned and rebuilt carb. Also noticed today that my armature plate has a little bit of play in it. Checked the mounting screws and they are tight. What more can I do? I just don't understand why it won't even 'pop' when I pull on the starter rope. Any help would be greatly appreciated.
Thanks, Bob
3. New condensers
4. New plug wires
7. New impeller
9. New fuel lines
10. Lync/sync'd
11. Rebuilt carb
Thanks, Bob
