bassin'frog
- Apr 27, 2011
- 103
Hey Guys! I have spent the past 6 months or so overhauling this motor. Originally bought it from P.O. who stated it ran fine last time he had it out, but it had been sitting in his garage for 2 yrs after that. I bought it and did the following:
-Replaced coils, condensers, points, plugs, plug wire
-Replaced impeller
-Cleaned and rebuilt carb
-Replaced all fuel lines
-Installed clear in-line fuel filter between fuel pump and carb
-Cleaned and inspected L/U
-Adjusted timing advance
-Got compression of 90 psi for both cylinders
-Got crisp spark of ? inch on spark tester
Today, I loaded motor into test drum and experienced the following:
-Sprayed fuel/oil mix directly into both cylinders
-Pumped fuel bulb until it got hard, has I pumped it, fuel filter filled up AND fuel poured out of the choke valve area
-As I pulled the starter rope, the fuel filter emptied, fuel stopped pouring out of the choke valve area, and every once in a while I got a loud pop out of the motor
As I pulled the starter rope, I did not see more fuel coming into the fuel filter
-If I pumped the already hard fuel bulb, the fuel filter would fill up but I didn?t see more come out of the choke valve area
So, this is where I am at?. Not sure where to go from here?.. Any recommendations would be greatly appreciated?. Thanks guys!
-Replaced impeller
