I've got a '68 Johnson 40 H.P. Electric start, I put in a new key switch and the key switch has a terminal that is labeled magneto. this terminal has continuity with ground when the key is in the off position. I am assuming I can use this to kill the motor when it's running but what do I wire it to in the motor? there was no kill switch in the boat previously I'm assuming they used the choke to kill the engine.
